Inventor Forum
Office 2010 and Inventor
9 REPLIES 9
Message 1 of 10
1430 Views, 9 Replies
I thought having 12 Gig of Ram my machine would be heaps fast.... Think again.... Just wondering if there is a problem with Office 2010 and Inventor...
It takes about a minute to copy, Material properties from one file to about 10 in Bill of Materials.
9 REPLIES 9
Message 2 of 10
pauldoubet
One reason you might not be seeing as much of a speed increase is that Inventor is not a multi-threaded application.
Inventor and Office 2010 are not compatible and won't be until Inventor 2012 is released.
Hope this helps, Paul
Message 3 of 10
Jon.Dean
Take a look at the following link, it explains in more detail:
http://beinginventive.typepad.com/being-inventive/2010/07/can-you-use-excel-2010-in-inventor.html
Jon Dean
Message 4 of 10
in reply to: Jon.Dean
What about Office 2010 (not just excel) causing interference in general?
My machine hangs (20 - 30 part .iam's) doing the simplest of tasks, eg, copying BOM data, placing content centre parts
Message 5 of 10
g_petkov
I've been using Inventor 2011 Pro for 6 months now on Windows 7 x64 + MS Office 2010 x64. No problems whatsoever.
Editing iPart and iAssembly tables is lightning fast.
If you have issues with Inventor performance, they are NOT DUE to MS OFFICE 2010 compatibility!
Message 6 of 10
in reply to: g_petkov
Good to hear, thanks I can check that off the listSmiley Happy
Message 7 of 10
ravikmb5
i am using office 2010 and iv 2011 both on 64 bit machine
i dont see any issues here
iparts works smooth
HP Workstation xw 8400
Please mark this response as Problem Solved if it answers your question.
Ravi Kumar MB,
i7 860 Dell Studio XPS Win 7 64 bit 12 Gb RAM & HP Z220 SFF Workstation
Autodesk Inventor Certified professional 2016
Email: ravikmb5@gmail.com
Message 8 of 10
I am working on 64bit Windows 7 with Inventor Pro 2011. I had no any issue with the Office 2007, but after a special offer of the Microsoft I upgraded the Office to the 2010 version. After this step I lost the iPart parameter editing function in Excel. I installed the Excel from the Office 2003 package, but it does not work. You are kindly requested to tell me, how can I set the Inventor, for using of the Excel 2003.
Many thanks in advance
Message 9 of 10
g_petkov
Vlaci69,
Like I said, I've never experienced any problems using Excel 2010 on Inventor Pro 2011. It looks like you've messed up your registry while upgrading from Office 2007 to 2010. If I were you, I'd reinstall the computer - this is the shortest procedure. Since you're using a 64-bit windows 7, I'd advise you to use the 64-bit Office 2010 and then install Inventor 2011 Pro.
Message 10 of 10
Many thanks for you answer. I think, I found the keyword in your message: "64bit Office 2010". There was only the 32 bit version in the special Microsoft offert, maybe my probleme is based on the 32bit Office. I will reinstall my computer with the 64bit office and I hope it will work.
Best regards
