style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
"Andrew Pawelski" <
href="mailto:andrew.pawelski@valiantREMOVEmachineTHIS.com">andrew.pawelski@valiantREMOVEmachineTH...>
wrote in message
href="news:9EE09F8ED430506C25E49F7068921961@in.WebX.maYIadrTaRb">news:9EE09F8ED430506C25E49F70689......
Wayne,
I'm going to post a STEP file for you in CF under this thread title.
This is the file that was directly exported by Catia V4. Bring it into IV6 and
you get a 2 part assembly, the large part is one body. Bring it into MDT6 and
you get a file with a part and a subassembly, the subassembly contains a
handful of separate parts (like Catia intended).
Also, the MDT problem using regular 3D solids still exists as well.
Andrew
"Wayne Catalfano" <
href="mailto:wayne.catalfano@autodesk.com">wayne.catalfano@autodesk.com>
wrote in message
href="news:F16B4F39C19B0E4F895579706729EA44@in.WebX.maYIadrTaRb">news:F16B4F39C19B0E4F89557970672......
Andrew,
Thanks for the posting.
I found only 2 "PRODUCTS" in this STEP
file. According to my contact at Dassault this indicates that
it was modeled in Catia as 2 parts, not as
assemblies. Please let me know if you can dispute this.
Can you go back to the source and confirm that these are indeed assemblies in
Catia?
Regarding MDT and older versions of
Inventor. Those systems were decomposing these parts into
assemblies. Clearly that's what you would like in this case, however,
that behavior did not conform to the STEP specification. At this
time it appears that Inventor is importing the data as Catia
intended.
Thanks for raising this issue and for
your feedback.
Wayne
"Andrew Pawelski" <
href="mailto:andrew.pawelski@valiantREMOVEmachineTHIS.com">andrew.pawelski@valiantREMOVEmachine...>
wrote in message
href="news:9EE09F8ED430506C25E49F7068921961@in.WebX.maYIadrTaRb">news:9EE09F8ED430506C25E49F706......
Wayne,
title. This is the file that was directly exported by Catia V4. Bring it
into IV6 and you get a 2 part assembly, the large part is one body. Bring it
into MDT6 and you get a file with a part and a subassembly, the subassembly
contains a handful of separate parts (like Catia intended).
well.
Andrew
"Andrew Pawelski" <
wrote in message
href="news:C9D558791EBB7EC90C25D7CB469BE67A@in.WebX.maYIadrTaRb">news:C9D558791EBB7EC90C25D7CB469......
Wayne,
These were assemblies according to the Catia
operator. I remember because he genereated four different files, trying
different settings on export for me to see all the parts
individually. Eventually I imported into MDT and they all worked
there.
Mind you, I have recieved Catia data since then
that has imported correctly into IV6. This may have been isolated to
the handful off assemblies I experienced this with last week.
Thanks for your help with this issue. What
about the MDT issue with regular 3D solids combining when going to IV6 through
STEP? Is that something that will eventually get repaired or is that not
supposed to work since they are not intelligent MDT parts?
Andrew
Andrew,
It's good to know that Catia assemblies often
import as expected. This feedback combined with the feedback from
Dassault leads me to believe that the Catia operator is actually
creating the assembly as a single part or doing something to export
it as a single part.
Regarding MDT. I was not involved with
the MDT STEP translator and I can't comment on why it was designed to create a
single part from the ACAD 3D Solids. The issue has been raised with the
MDT team and they will consider how to address it.
- Wayne
"Andrew Pawelski" <
wrote in message
href="news:C9D558791EBB7EC90C25D7CB469BE67A@in.WebX.maYIadrTaRb">news:C9D558791EBB7EC90C25D7CB4......
Wayne,
there.
then that has imported correctly into IV6. This may have been
isolated to the handful off assemblies I experienced this with last
week.
through STEP? Is that something that will eventually get repaired or is that
not supposed to work since they are not intelligent MDT parts?
Andrew
size=2>
"Wayne Catalfano" <
wrote in message
href="news:280C28FC9E042B10B867CDD323574DFE@in.WebX.maYIadrTaRb">news:280C28FC9E042B10B867CDD3235......
I just got some feedback from the MDT team.
You can create blocks in ACAD to identify your parts. The MDT STEP
export treats blocks and block references as individual parts. Entities
that are not in a block are placed together in a part.
- Wayne
"Wayne Catalfano" <
wrote in message
href="news:4EC18B110361D586B3B42020ABCC86BD@in.WebX.maYIadrTaRb">news:4EC18B110361D586B3B42020ABC......
Andrew,
export it as a single part.
with the MDT STEP translator and I can't comment on why it was designed to
create a single part from the ACAD 3D Solids. The issue has been
raised with the MDT team and they will consider how to address
it.
- Wayne
"Andrew Pawelski" <
href="mailto:andrew.pawelski@valiantREMOVEmachineTHIS.com">andrew.pawelski@valiantREMOVEmachi...>
wrote in message
href="news:C9D558791EBB7EC90C25D7CB469BE67A@in.WebX.maYIadrTaRb">news:C9D558791EBB7EC90C25D7C......
Wayne,
Catia operator. I remember because he genereated four different
files, trying different settings on export for me to see
all the parts individually. Eventually I imported into MDT and they all
worked there.
week.
that not supposed to work since they are not intelligent MDT
parts?
Andrew
size=2>
