Inventor General Discussion
CelticDesignServices
Message 1 of 6 (187 Views)
Odd happenings in Inventor
187 Views, 5 Replies
05-14-2012 09:18 AM
OK, just started noticing this issue this morning. I'm in an assembly and during the Constrain command, the "preview" option is not only deselected, but it's not even available:
Which of course doesn't show the action or the result of the applied constraint as you perfrom the command.
But not only do I no longer get the preview during the command, I don't get the result AFTER I apply the command (see above). No "boink" noise either (not a bad thing mind you).
But in order to see the result of the Constraint command now, I have to select a new command:
None of the parts are adaptive:
Inventor has been closed and restarted. Next step is to reboot (restarted computer this morning)
Jim
Celtic Design Services, LLC
Inventor/AutoCAD/Vault WorkGroups
Always for hire - celticdesign01ATyahooDOTcom
https://www.facebook.com/pages/Celtic-Design-Services-LLC/184666001666426
Please use the "Accept as Solution" and "Give Kudos" functions as appropriate to further enhance the value of these forums.
Go raibh maith agat (in other words...Thank you!)
Yep, defer update was not checked (it was one of the first things I looked at, guess I should have mentioned such).
A complete shutdown and restart cleared everything up now.
Wierd stuff on a Monday. I should have called in sick and stayed in bed.
It's only 9:30am and with about 2 hrs of sleep under my belt last night, it's feeling more like 11:00pm right now.
I'll try not to get too punchy here as the day goes on....although that might be a little entertaining....:smileywink:
mrattray
Message 2 of 6 (184 Views)
Re: Odd happenings in Inventor
05-14-2012 09:22 AM in reply to: CelticDesignServices
Did you check that the Defer Update option is unchecked?
Mike (not Matt) Rattray
mcgyvr
Message 3 of 6 (181 Views)
05-14-2012 09:25 AM in reply to: mrattray
and have you restarted both the computer and Inventor.. I've had similar and a restart cleared it right up.
2015 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
Message 4 of 6 (176 Views)
05-14-2012 09:34 AM in reply to: CelticDesignServices
Jim
mrattray
Message 5 of 6 (159 Views)
05-14-2012 10:16 AM in reply to: CelticDesignServices
Everyday is a wierd Inventor day for me. Just now Inventor decided that it's not going to display certain parts when in their assemblies. Time to reboot for the third time today...
-niels-
Message 6 of 6 (94 Views)
05-14-2012 11:07 PM in reply to: CelticDesignServices
The "(Shaft)" bit of the assembly's name isn't a Position is it?
Because i don't think you can constrain stuff when in a positional representation.
Using IV2014 Pro SP2 - upd.1, Win7-64bit
