Hi all
I just popped off to a meeting, and when i returned the Object Browser has dissapeared from my screen and i cant get it back.
Has anyone any idea where it might have gone or how i can get it back.
Thanks in Advance.
Solved by jdkriek. Go to Solution.
yes i have that it ticked but no browser. That was teh fist place i looked.
If i tick it off and on nothing happens.
Did you reboot the computer and the problem persists?
Are you running two monitors?
More information is needed.
no reboot,
but i am running two moniters.
as i said in the first post, it was fine, i went to a meeting, when i get back its gone.
From the Windows start menu command line type regedit
Navigate to HKEY_Current_User > Software > Autodesk > Inventor > RegistryVersion 17.0 > DockingAreasRibbon > BrowseBar
Look for the Floating name in the panel on the right and double-click on it.
Change it's value from 1 to 0 then hit ok. Then Restart Inventor. Should work.
@Anonymous
You are talking about a 6 year old posting here...
Are you saying when you go to View/User Interface, the model browser is checked but no where on the screen?
Mark Lancaster
& Autodesk Services MarketPlace Provider
