Sorry, I wizzed throught the project to quickly.. select Wrap in the 3D
sketch - Project to Surface.... BIG difference. But, you can edit my 3D
sketch to fix it... 🙂
Dennis Jeffrey, AICE, MICE
260-399-6615
Instructor/Author/Sr. App Engr.
AIP 11SP2, AIP 2008
HP Pavillion Zv5000 (Modified)
Geforce Go 440, Driver: .8185, 2GB RAM
XP Pro SP2, Windows Classic Theme
http://www.design-excellence.com
"Dennis Jeffrey" wrote in message
news:5592314@discussion.autodesk.com...
I would do a 3D Sketch, then sweep a circle profile.
Here's a procedure from my book:
1. Create a simple circle sketch, anchor to part origin centerpoint
2. Create a work axis and a tangent workplane
3. Create a circle, anchor and dimension
4. In 3D sketch, select Project Curve to surface. Pick surface, then the
circle.
5. Create workpoint using origin plane and curve,
6. Create New Sketch using the same origin plance.
7. Create a circle on the workpoint. Dimension and anchor.
8. Sweep th
e cut.
An R11 example is attached. This procedure woorks in previous versions as
well.
260-399-6615
AIP 11SP2, AIP 2008
wrote in message news:5592159@discussion.autodesk.com...
What command do I use to place an O-ring groove on a shaft as shown in the
attachment?
I've tried different methods unsuccessfully.
