I upgraded from Inventor 2010 to 2014 on my Dell M4600 last week and it is running extremely slow and with loads of faults:
I am seeing missing letters from words in the ribbon menu
Pan function will not work
Many of the 'I' menu functions will not work i.e. Open,Save As, Save Copy As etc
Right click menu will not appear until the mouse is moved after right click
I have used the uninstall tool to clean the registry and perform a clean uninstall and re-installed this with virus protection switched off. I have also installed SP1 but saw no improvements and it is mostly unworkable.
I have been in touch with the support team that sold us the Inventor 2014 suite and they have told me that the NVIDIA Quadro 2000M is not suitable for use with Inventor 2014 and that it is a hardware issue.
When I got this computer 18 months ago this was the top of the range card available and I am surprised that this would be unsupported after such a short amount of time.
I have updated drivers for the NVIDIA card, the Intel onboard graphics and the latest BIOS. I've tried compatibility/performance modes and switching Optimus off via the Bios but nothing has helped.
Has anyone else got Inventor 2014 working with this graphics card?
I would reallly appreciate any help on this as I'm not sure it will even be possible to change the NVIDIA card to another type.
As this is a laptop then your stuck with it as these usually part of the laptop main board the 2000M is not a card certified by Autodesk BUT that dose not mean that it will not work, it may just mean that it has been tested and the page not updated as Autodesk seem to be a bit slow on this.
There is a list of all the certified card here :-
Second option is to go to the DELL website and find the lates driver for this card as it may have been specifically produced for Dell, and a note here to others who may have the same card in lets say a Samsung, that the drivers are produced specifically for that make/manufacture of a specific laptop and that there will be some differences in the performance and drivers.
I have tried searching for an autodesk certified driver however there does not seem to be one for inventor - only autoCAD. I understand there are multiple drivers and so I was hoping someone out there might be running the same Dell M4600 with the same spec on Inventor 2014 to try and narrow down which driver might work.
There must be others out there who have tried (successfully or unsuccessfully) to run Inventor 2014 on this GPU??
I ran the smart scan tool on the NVIDIA website to determine the most compatible driver for this machine. I believe it was the same one as I downloaded from Dell.
My alternative is to try all the different drivers listed for various other applications on the INVIDIA website:
Quadro ODE Graphics Driver
Quadro Performance Driver
Quadro Partner Certified Driver
AutoCAD performance Driver
3DS Max Performance Driver
Mosaic Utility
Mercury Transmit Plugin
The link sent for the other thread seems to discuss the NVIDIA 2000 card not the NVIDIA 2000M which is the mobile version. I would assume the 2000 drivers will be totally different to the M version.
The Quadro 2000M isn't, and has never been, top of the line video hardware. Its an entry level card which should be OK for Inventor work. But thats kind of beside the point. Most of the problems with video hardware I've seen stem from conflicts between a dedicated video card and on-chip graphics, specifically with the nVidia Optimus technology which should choose the appropriate hardware for any given task (ie. low performance/power consumption for movies, apps, etc. and high performance/power consumption for high end software like Inventor). First order of business is making sure the dedicated video card is in fact being used, and isn't conflicting with any on-chip graphics hardware.
Hello.
I have Lenowo ThinkPad W530 workstation with Quadro K2000M. Recently i've got an offer to upgrade IV 2012 to 2014 so i'm testing the trial version right now. As for now i don't see any problems with performance or faults.
