Howdy all,
Curious, I am trying to get numbers 'engraved' (extruded) into a diameter of a dial ring. I was able to create a couple of planes to create the marking lines around the OD, but am unsure how to add numbers and extrude said numbers (in the easiest fashion possible). I need to go from 0 to 90 on the longest marking that starts at 0° and is every 36°.
Also, that being said, with the little I tried and was unhappy with, I created a text box at the 0° marker but the text was in the wrong rotation the marker and rotation box was greyed out. How can I resolve this...or is it even related?
File attached.
Appreciate any help! 🙂
Tks!
-R
Hi Talayoe,
Here is one approach to getting text around a dial, I have added a text to a sketch and re-aligned the text by Right clicking over the text and Un-checking the tick box by the word “Text Box”. You should now be able to rotate the text to angle required.
P.s.
Drag the End of Part Marker to the end of the feature tree as the file size get quite large when adding lots of extruded text
Hope this helps
Cheers
Mark
Inventor 2014
