Inventor General Discussion
Member
crepps581
Message 1 of 5 (488 Views)
notch beams perpendicular to each other
488 Views, 4 Replies
10-25-2011 12:19 PM
I have a situation where need to frame a W14x30 into a W14x61.  When I perform the Notch command, the W14x30 is only partially notched. The W14x61 is taller by .05 in. I tried to notch the W14x30 by ending it at the flange edge of the W14x61.  I also tried to notch by ending the W14x30 on the other side of the W14x61, both attempts yielding no results.  Any guidance to resolve this is greatly appreciated.
JDMather
Message 2 of 5 (483 Views)
Re: notch beams perpendicular to each other
10-25-2011 12:22 PM in reply to: crepps581
I think you will need to first increase the length so that they intersect.
Can you attach the assembly here?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015-SP1 64-bit
Member
crepps581
Message 3 of 5 (482 Views)
10-25-2011 12:23 PM in reply to: crepps581
Found a solution to my own question:  Trim/Extend W14x30 to the face of W14x61, then Notch.
cbenner
Message 4 of 5 (476 Views)
10-25-2011 12:25 PM in reply to: crepps581
I might add, from experience, anytime you are doing a notch function that also requires a trim... do the trim first, so that the G_L cut length will be correct.  We've found (at least in 2011) that if you notch first and then trim, the length value does not update.
ChrisB
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
http://cbennertipstricks.blogspot.com/
Member
crepps581
Message 5 of 5 (474 Views)
*face of the W14x61 web
