Thanks for reading all,
I have downloaded Inventor 14, and the program appears to start up without problems. However, when i create a simple sketch, it first says "Choose a plane". In my textbook, it shows a piciture of the three planes to choose from. However, my computer screen shows a blank gray screen. It appears some tool bars are missing as well.
However, if i click in the space where I imagine the axis should be, it takes me into sketch mode.
Similarly, when I draw a line, the information bar reads like I am drawing a line, but no line shows up on the screen.
Is there a specific requirement on my computer I could be missing? I have downloaded Inventor twice, and both times had the same problem with the program. Perhaps a video card I need to have, or a certain RAM requirement?
Thank you!
welcome to the forum.
Can you post your system hardware details? (and driver versions)
Did you install it as recommended - as an admin with anti-virus and UAC off?
Sam M.
Inventor and Showcase monkey
Please mark this response as "Accept as Solution" if it answers your question...
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos - spread that love 😄
Maybe check your hardware against the AutoDesk minimum requirments for 2014?
From AutoDesk's webpage:
System requirements for Autodesk Inventor 2014 products
For Inventor 2014 Windows users
For general part and assembly design (typically fewer than 1,000 parts):
•Windows® 7 (32-bit minimum, 64-bit recommended) or Windows® 8 64-bit[1] operating system
•Intel® Pentium® 4, AMD Athlon™ 64 with SSE2 technology, 3 GHz or greater, or AMD dual-core processor with SSE2, 2 GHz or greater recommended, or Intel® Xeon® E3 or Core i7 or equivalent with SSE2, 3.0 GHz or greater
•4 GB RAM minimum for less than 500 part assemblies (8 GB recommended)[2]
•15 GB free disk space for installation
•1,280 x 1,024 or higher screen resolution
•Microsoft® Direct3D 9® or compatible graphics card (Microsoft® Direct3D 11® or higher recommended)
•Microsoft® Internet Explorer® 6 or later (.NET Framework Version 4.5 web browser)
•Microsoft® Excel® 2003 or later software for iFeatures, iParts, iAssemblies, thread customization, and spreadsheet-driven designs
•Adobe® Flash® Player 10
•Internet connection for web downloads and Subscription Aware access
•Microsoft-compliant mouse or pointing device
•DVD-ROM drive[3]
In addition to the other suggestions you might go to Tools>Application Options>Hardware tab and set to the lowest setting (might need to reboot or at least restart Inventor).
