1. Right click on Trim-Extend as shown From Edit with Frame Generator.png.
2. From the Edit Trim - Extend To Face dialog box, the Frame Member and Face selection is not enabled (see Not Editable.png).
I want to change the Face reference.
This should be editable, right? Any ideas?
Jerome
I see that there are end condition errors in some of your frame members... could these be causing you some conflicts? Try resolving those, and see if it helps.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Are these "Stock" CC items or are they custom items/shapes that you have published?
Are you current on all SP's and hot-fixes for your product?
@Anonymous wrote:Are these "Stock" CC items or are they custom items/shapes that you have published?
Thanks Blair
These frames are inventor CC files.
Inventor 2014 SP1.
Check the build from image.
