Inventor General Discussion
Active Contributor
wengerbryan
Message 1 of 5 (2,064 Views)
Normal Cut in Sheet Metal
2064 Views, 4 Replies
09-06-2012 03:42 PM
Quite a few comments have been made about how incredible it is that Inventor still does not have a functional normal cut option for sheet metal like Solidworks and Solidedge have long had and I agree.  I realize that there are the standard workflows like using derive and thicken to get around this problem.  However, for those interested, there is a way to make a normal cut (for laser/cnc) directly in the sheet metal part in many cases.  It involves using a sketch to split a face and then using the resulting profile for a thicken/cut feature.  The attached images illustrate somewhat.  I'm always interested in any other methods out there for obtaining normal cuts in complex sheet metal (for a clean dxf export).  By the way, Autodesk, do you actually not have any plans of ever adding functionality in this area?
Inventor 2013
Inventor 2012 SP2
Vault Collaboration 2013 SP1
Dell Precision T3500, Xeon W3503 2.4GHz, AMD FirePro V4900
Windows 7 64-bit, 8 GB RAM
mrattray
Message 2 of 5 (1,970 Views)
Re: Normal Cut in Sheet Metal
09-07-2012 07:54 AM in reply to: wengerbryan
This is my method, although many here seem to shy away from it.
Mike (not Matt) Rattray
Active Contributor
wengerbryan
Message 3 of 5 (1,938 Views)
09-07-2012 10:33 AM in reply to: mrattray
Yes, that will result in a true sheet metal cut as well and its a good way to get true round cutouts in the flat layout, but if you want a true round in the rolled part (to insert a pipe, etc.) you can't get there that way.  Thanks for your reply.
Inventor 2012 SP2
Lance_White
Message 4 of 5 (1,916 Views)
09-07-2012 11:59 AM in reply to: wengerbryan
i JUST GO TO THE FLAT PATTERN AND EXTRUDE THE EXCESS MATERIAL OUT.
Lance W.
Inventor Pro 2013 (PDS Ultimate)
Vault Pro 2013
Windows 7 64
Xeon 2.4 Ghz 12GB
mrattray
Message 5 of 5 (1,906 Views)
09-07-2012 12:18 PM in reply to: wengerbryan
