Inventor General Discussion
Valued Mentor
GSE_Dan_A
Message 1 of 8 (339 Views)
Normal Behaviour? - Re: Circular Pattern
339 Views, 7 Replies
10-30-2012 01:01 PM
Hello all,
Not sure if this is normal behaviour for IV 2013 (with SP 1.1 installed).  When changing a circular hole pattern quantity (ie from 6 instances to 8), the additional 2 holes do not appear in the part after finishing command.
Steps I have performed....
1. Create a circular pattern on part surface (6 holes)
2. Use Hole command to generate holes in part (everything works as expected).
3. Go back into sketch with circular pattern and change instances from 6 to 8 and finish sketch.
The 6 holes will be visible, but the last 2 holes additonal holes are not present.
When going in reverse (from 8 holes to 6), the part updates as expected.
This may be typical in how Inventor handles this, but one would think that when you change the pattern, the holes should update to the correct number in the part.  The only way around this is to go into the Hole feature and manually select the 2 additonal points.
GSE Consultants Inc.
Windsor, ON. Canada
Does exactly the same here.
I would put in one hole, then pattern the feature.
It will then update as you want.
Distinguished Mentor
john.retzlaff
Message 2 of 8 (327 Views)
Re: Normal Behaviour? - Re: Circular Pattern
10-30-2012 01:21 PM in reply to: GSE_Dan_A
Assuming you have created the large circle with the hole pattern in it as one extrusion, you will have to reselect the profiles, then deselect the 2 new holes.
John Retzlaff
Valued Mentor
GSE_Dan_A
Message 3 of 8 (319 Views)
10-30-2012 01:27 PM in reply to: GSE_Dan_A
John,
Thank you for your response.  The pattern was generatred after the extrusion of the round plate.  The hole pattern is done within Sketch 2 and then I use the Hole feature to create them.  Once I execute this command and go back to sketch 2 to change the instances, the part will not show the additional holes.  (like in my previous example of 6 holes to 8, the addional 2 holes will not show up).  As I mentioned before, you would think the pattern would update seeing as the Hole feature is dependent upon Sketch 2 (where the circular hole pattern is located).
Windsor, ON. Canada
Valued Mentor
GSE_Dan_A
Message 4 of 8 (316 Views)
10-30-2012 01:35 PM in reply to: GSE_Dan_A
Here is a snapshot of my browser and the part showing the sketch2 visibility and how the part looks once I change it from 6 to 8 holes and then complete the command.
I know this is a very small inconvenince compared to other bugs/behaviour that is within this program, but I just thought I would bring it up as it may be an error in my workflow or my installation of IV.
Windsor, ON. Canada
john.retzlaff
Message 5 of 8 (310 Views)
10-30-2012 01:54 PM in reply to: GSE_Dan_A
John Retzlaff
Valued Mentor
GSE_Dan_A
Message 6 of 8 (299 Views)
10-30-2012 01:59 PM in reply to: john.retzlaff
Thanks John for confirming.  So I suppose its not a bug and just my workflow... Glad I have this confirmed and sorted.
Windsor, ON. Canada
JDMather
Message 7 of 8 (292 Views)
10-30-2012 02:40 PM in reply to: GSE_Dan_A
You can edit the Hole feature and click the additional points, but pattern of sketch enities should always be used as last option - pattern of features is more robust technique.
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
Valued Mentor
GSE_Dan_A
Message 8 of 8 (261 Views)
10-31-2012 05:35 AM in reply to: GSE_Dan_A
Thanks JD for the tip.  I convinced my boss to buy Curtis' and Wasim's book from Amazon as per yours (and others) suggestion.
Windsor, ON. Canada
