When creating a single flange, I set the Relief Shape ="Default" and set Relief Width=.001 to eliminate bend reliefs in the flat pattern. There will still be a line (relief shape) in the flat pattern, but that can be hidden in the .idw file.
For creating "corner to corner" flanges, I use the Corner Seam command and set the Gap=.001 and Relief Shape="Tear"
Hope that helps
