Inventor Forum
No Vault Tool bar 2013.
1 REPLY 1
eric.mathews
887 Views, 1 Reply
I recently installed Vault pro 2013. I was running Inventor 2012 at the time.. My vault add-in stopped loading. I installed Inventor 2013 and the vault add-in still won't load. I've gone to the Add-in manager 2013 and set it to loaded. I hit the "OK" button and nothing. Open the manager up again and it says "unloaded". Something is going on that is not allowing my vault add-in to load. This is very frustrating. Any suggestions?
1 REPLY 1
Jon.Dean
in reply to: eric.mathews
Have you tried changing the Vault Client from Programs and Features?
  1. Right click on the Vault Client and select Change.
  2. Now select Add / Remove Features.
  3. Un-check the Add-in for Inventor.
  4. Update.
  5. Now go back and this time check the option to add the Add-in.
  6. Update.
Hopefully this should work OK.
Jon.
Jon Dean
