Inventor General Discussion
Active Contributor
14 Kudos
Post 1 of 4
No text shows using hole annotation tool in inventor 2011
441 Views, 3 Replies
01-17-2011 02:47 PM
I'm using inventor 2011.  I'm creating a drawing for a part, and when I attempt to annotate a hole, no text shows up.  Just a blank leader line.  The hole is a thru hole, but when I change it to another type, (like "distance" or "to") it will give me the text.  So what am I missing?  I've made other parts where I don't have this issue, but nothing works recently.
When you edit the blank thru hole note, what do you see?  You should see something like this:
<QTYNOTE>Ø<HDIA> THRU.  If not, your style library and/or template needs some remediation...
Valued Mentor
112 Kudos
Post 2 of 4
Re: No text shows using hole annotation tool in inventor 2011
01-17-2011 08:37 PM in reply to: ihiengdept
This may be a stupid question but I'm gonna' ask it anyway: Have you looked at your style library to make sure the note for a thru hole hasn't been edited/deleted? I've never encountered this issue, it's just the first thing I though of.
Inventor Professional 2013 (SP-2.3), Product Design Suite Ultimate
Desktop: Intel Core i7 3.4GHz, 16.0 GB RAM, Windows 7 Ultimate SP-1, 64-bit OS, (2) GeForce GTX 580 (331.81), Space Pilot Pro (3.16.1)
Laptop: Intel Core i7 3.9GHz, 16.0 GB RAM, Windows 7 Pro SP-1, 64-bit OS, GeForce GTX 780 (331.81), SpaceNavigator (3.17.7)
*Pro
284 Kudos
Post 3 of 4
01-18-2011 05:01 AM in reply to: ihiengdept
Active Contributor
14 Kudos
Post 4 of 4
04-20-2011 05:32 AM in reply to: sbixler
Things got busy and it took me a while to get back this, but both replys were right on.  Somehow that one definiton for a THRU hole got completely deleted in the style library for a template I was using.  I'm still fairly new to autodesk so I really appreciate the help.
Thanks!
