I have no template files in Inventor. Any idea where they are or where I could download them? I obtained this software through a school license by georgia tech.
I am having the same problem, I am running Windows Vista, and Inventor professional 2011 Student Version.
I am not sure if you can't fine your templates, or they dont exist at all...
The default template locations are defined here:
TOOLS - APPLICATION OPTIONS - FILE (tab) - Default Templates
However the project file (.ipj) can override this...
Open the Projects dialog box...in the lower half, expand FOLDER OPTIONS...here you will see the location of the templates.
OR
the default templates can be found here:
...\Program Files\Autodesk\Inventor 20xx\Templates
If you don't have any templates in this location...I attached the "standard" (nonmetric) templates that Inventor comes with.
Thank you very much. I was missing the template files so the atachment worked perfect. Again much thanks.
Do you have also the metric template files for inventor 2014, because I can't find them anymore?
Have installed it with student license for europe.
Many Thanks
You can always create your own template files and place them in the directory specified in the application options.
These are actually better because they have your personal settings.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
