I am using Autodesk Inventor 2013 Pro, downloaded from the student area and there is no stress analysis feature. can this be activated in the student edition?
Also, the software runs as "UNREGESTERED VERSION" even though i have registered with Autodesk.
Any advice would be appreciated as I need the abity to test a variety of stress analysis on models before optimisation.
Mike
Solved by JDMather. Go to Solution.
The student version is fully functional.
Post screen capture of your Environments tab on the ribbon.
Did you install with anti-virus and UAC turned off?
Post screen capture of Help>About Inventor>Product Information but obscure the serial number.
Post screen capture of Add-in Manager.
The CADWhisperer YouTube Channel
My bad, thank you very much JDMather, it was in the Environments section. Am still finding my feet with inventor so had been looking for it as a locked tab.
Thanks again
I use the Autodesk Inventor Professional 2014 , downloaded from the student area and there is no stress analysis? can anyone help me? please.tq.
I have similar problem.
The results don't show up after simulate.( I am doinf modal anaysis by the way)
Attach your *.ipt file here.
Have you installed all Service Packs and Updates?
