I just tried with a file similar to the one you show in the picture, and it seemed to do
what I think you want.
In Inventor use File Open and open the MDT DWG. You will get just the solid (at least I
did). Then start a new sketch and import it again, and it will allow you to select the
layers to bring in to that sketch.
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"Jerome" wrote in message
news:F6295A8B4A28E9C3D53B9094BFD8C367@in.WebX.maYIadrTaRb...
> Does anyone know of any workaround on Importing MDT file
> with layers (similar to autocad import options on layers)?
> red circle was defined as a layer.
> thanks,
> Jerome
