Inventor General Discussion
Valued Mentor
tmccar
Message 1 of 5 (210 Views)
No balloon around numbers
210 Views, 4 Replies
08-15-2012 06:44 AM
I am putting balloons on an assembly drawing, but the circle is not appearing. The arrow, leader and number are there, but  no circle. What could be wrong?
Under the manage tab you have style and Standard editor in that are all the standards.. See Pic.
*Pro
jletcher
Message 2 of 5 (206 Views)
Re: No balloon around numbers
08-15-2012 06:57 AM in reply to: tmccar
Well I don't know you don't explain or tell us anything. What is your style of balloon set to is it set to show a circle? If so then a version of Inventor would be nice so those that had an issue with balloons will know if it is the same issue they had  and can tell you how they fixed it.
James Letcher
2012 Factory Design Suite ( will not load 2013)
What happen to my Inventor :-(
Valued Mentor
tmccar
Message 3 of 5 (195 Views)
08-15-2012 08:41 AM in reply to: jletcher
It's Inventor 2012. Where do I set the balloon style?
*Pro
jletcher
Message 4 of 5 (191 Views)
08-15-2012 08:50 AM in reply to: tmccar
James Letcher
Valued Mentor
tmccar
Message 5 of 5 (163 Views)
08-16-2012 02:13 AM in reply to: jletcher
That's it, thanks
