I am more curious if anyone has encountered this before than anything, although if you know why this is happening, I would like to know.
I have a sketch for a 1.125" tall bounding wall. The inside contour is projected, and the outside contour is offset .125." When I extrude the desired profile, the inside corners, which are project radii, turn inside out. I don't know how else to explain it. I will attach before/after screen shots.
I reboot my PC at lunch because I was getting other odd errors, lots o' C++ runtime joys. That was some two hours ago, and I had a slew of errors/crashes after that around one. Now, no error messages, but this interesting occasion.
-E
yes that can happen on occasion..
