I am a newbie to Inventor, who do not even know the appropriate terms (jargon) to search for. Hence I am asking this in this forum. I am ready to learn through documentation and other resources. I just need to know the term to serch for.
Basically I am evaluating to model rebars in Inventor. Rebars come in predefined shapes - for example a "L" bar will have two dimensions (marked as A, E and R). The shape definition is fixed by a standard (like BS:8666) and the values for dimensions A, E and R are provided when it is instantiated as a part in an assembly.
I created an assembly as follows:
My questions:
Many thanks for your time,
Narayanan
Solved by BarryZA. Go to Solution.
I'm not sure why you created the cube?
Anyway, open an assembly and click place from content centre and choose a ramdom bolt. click on your workspace and you will be presented with a table, asking you which length of bolt and which thread size you want.
This is called an ipart and you can make your own one with your part.
Failing that, if I only need a couple of configurations, I save copy as of my original and edit the dimensions, so now you have 2 independant parts that will not affect each other.
@Narayanand wrote:
.... do not even know the appropriate terms (jargon) to search for. Hence I am asking
Narayanan
Search on the term iPart as indicated.
What version of Inventor are you using (2014)?
Someone here can create a simple iPart for you in minutes to show you the basic process.
Thanks for the info. I created the cube just as a matter of practice, but absolutely unnecessary for this question.
I tried iPart and it works well as I expected, but with one side effect. It creates a part file for each change in the dimenion that I make while inserting the part. Is there any way I can delete those part files, but still the part inserted in assembly still works? Like binding in Xref in AutoCAD...
Thanks again.
