Please see attachment. I cannot make the cuts in this bifurcated pipe.
This is is a problem that I run in quite often and I don't know the right method to handle this issue.
Individual parts build my assembly. The parts are constraint to eachother. Somewhere along the design process I want to create a part that needs the geometry of another part as base for a feature. Most of the time I can edit the part in the assembly, start a new sketch and use 'project geometry'.
As you can see, that method can not be used in this case.
'make component', 'derive', etc: where is the sollution?
The parts can be downloaded from: http://www.rschepers.com/data/broekstuk.zip
Can you help me?
rene
Edited by: hotreneke on Apr 11, 2010 8:31 AM
Edited by: hotreneke on Apr 11, 2010 8:32 AM
