Hello all.
I have this box I made https://grabcad.com/library/no-2# (also attached)
Here is a screenshot of a measurement I made:
All I need to do is make the box wider, so that the measurement between those 2 points is 49 instead of 42.
I don't mean stretch everything, but simply extend the the middle parts of the box on the left and right side of the circular funnel thing by 3.5mm
How would I go about doing this? Honestly, if someone could even just do it for me and upload it, I would be very appreciative. If not, I'll try my best to figure it out.
Solved by johnsonshiue. Go to Solution.
weird, I made it in inventor. I'll probably just start over. It shouldn't take too long.
The file you attached is a step file. If you want people to be able to work with it, you need to attach the .ipt file and tell us the version it was created in.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Unfortunately, my computer was whiped and all I had was the .stp file I had put into dropbox.
I know it was made in Inventor 2013 though.
I don't know what either of those are, sorry I am very new at inventor. 😕
IF you made the file in Inventor you have the "ipt" file..
You need to post that.. and that only or your are out of luck
Just like when you create a file in excel you make an xlsx file.
Or word a docx file
and if you have the ipt file you can easily just edit the model and fix it yourself.
NO way could you create a box like that but not know how to simple edit it in Inventor.
link didnt work. It's fine, I'll just redo the box from scratch when I get home. Thanks for the help guys!
WHY would you do that??????
Just edit the one you have..
Open the ipt file and edit the feature or features that control that dimension..
There is NO need to redo the box from scratch.. Well unless you really didn't have the ipt file in the first place.
OP lost the original .ipt The Step is all he has left to work with.
Open it in 2015 if you can and use the Direct Edit?
Chris Benner
Hi huttonji,
If you need to extend a "dumb solid" there are a couple of ways to do it. Attached is a method using the Split tool.
But you can also use the Edit Solid option in Inventor 2014 and previous versions:
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-53BF57D8-352B-4689-AE42-8C1BBCE38F92
Or the Direct Edit tool in Inventor 2015:
http://help.autodesk.com/view/INVNTOR/2015/ENU/?guid=GUID-E27FC7F0-1224-491C-84C2-EC2AE77171A2
I hope this helps.
Curtis
Oh yes.. didn't see message #8.
Hi! I don't think you need to redo it from scratch. I am pretty sure it requires more work to recreate it. However, it is not as straight forward to length just a section. There are a few tricks to play to get it as simple as possible. Please take a look at attached part and see how it was done. Let me know if you have any question.
Thanks!
Another attempt without removing and adding the hole.
