I can make a bracket object and add fillets, a chamfer and a properly sized hole but I can't position the hole to the proper location on the bracket, 3/8" from one edge and 7/16" from another edge. I can't get the hole to budge from its original location. Help doesn't seem to help, so I'm stuck. I can't even delete the hole! The Tutorials don't help and also reading Hansen's book on Inventor doesn't help. Hansen doesn't seem to say anything about positioning a hole. What's the trick?
Thanks!
There are 4 ways to place a hole:
here's a video (if you can see youtube):
http://www.youtube.com/watch?v=DUz9oH76aM4
I just noticed the above video was made by Thom Tremblay.
I have 2 of his books. This one is a very good beginner book:
http://www.amazon.com/Introducing-Autodesk-Inventor-2009-LT/dp/0470375523
also here is a very good tutorial video:
http://www.youtube.com/watch?v=zLyqAq2uNiw
I may look into buying the TheCADGorilla videos for our internal training, they seem very well done and are probably a much better value than training from our reseller.
Attach the file here.
Thanks very much for the URL's of the utube videos. They are terrific! But I still haven't figured out how to move or delete an existing hole and can't see how to re-size or even move my bracket. Is there a way to move an existing hole?
BTW, I am using Inventor 11, not Inventor 2011. We can't afford to upgrade to 2011, so perhaps Inventor 11 is the limitation, besides my own ignorance, that is. Perhaps I should try the 30 day trial version for this project.
Thanks again!
@Anonymous wrote:But I still haven't figured out how to ... delete an existing hole
Do you have your feature history browser dispayed?
Simply right click on the feature and select Delete.You might read this document http://home.pct.edu/~jmather/AU2006/MA13-3%20Mather.pdf
Attach your file here.
Thanks. Attached is my bracket. I can't move or delete the hole and can't move or resize the bracket. Of course, I could start over since the bracket is pretty simple, but starting over seems rather ridiculous.
Thanks in advance for you help!
Ah, "feature history browser?" What's that? I don't find "feature history browser" and Help doesn't list it. Of course, Help isn't very useful as far as I can tell.
I attached my bracket previously.
Again, thanks!
if you don't see the browser tree:
Go to menu "VIEW" Click "Toolbar", then click "Browser bar"
You most likely clicked on the little X at the top right of the browser bar turned it off.
Thanks BMiller63! Your suggestion worked to delete the hole when I clicked on the Sketch for the Hole, but then I had to delete Hole (under Model) to actually delete the circle on top of the bracket. So maybe I can start over with the hole, using the utube videos as instruction. The replies to my posting have been incredibly helpful and I see that this Discussion Group is excellent; the responses are terrific, but Inventor is all very frustrating and painful for this Newbie, so I can't bring myself to insert a Happy Face.
@Anonymous wrote:... to actually delete the circle on top of the bracket. So maybe I can start over with the hole,
Once you get experience - deleting and starting over is not a good way to move or resize a hole. The whole idea of parametric modeling is the ease of editing when a change is needed without doing rework.
Thanks JDMather. But now I have yet another (Newbie) problem. I have placed a rectangular pattern on my bracket, but I can't see how to locate or position the pattern. It's my same old problem, how to position an existing pattern or hole or whatever. I can move the rectangular pattern, but I don't know exactly where it is and can't establish its location. Or is there not a way to do this, that I have to position it correctly when I set up that pattern or other feature?
Thanks for your infinite patience with this Newbie!
Ok, got it, that is, I used General Dimension to set the position of my rectangle on my bracket. However, I don't know exactly how I did it so may not be able to do it again. Then I made holes at the corners of the rectangle. Now trying to make a pattern of holes, 3 x 6 holes in a pattern between the first set of four holes.
I would advise you to run a few basic tutorials - they would be able to help you out with a lot of basic questions
* built in tutorial in Inventor
* youtube Gorilla CAD
* any link JD Mather throws at you (http://home.pct.edu/~jmather/skillsusa%20university.pdf + http://home.pct.edu/~jmather/AU2006/MA13-3%20Mather.pdf + http://home.pct.edu/~jmather/content/DSG322/inventor_surface_tutorials.htm)
* maybe even a book: Autodesk® Inventor® 2011 Essentials Plus
Edited: Came off cocky unintentionally, edited text.
Thanks for the screen capture BMiller.
I have just started to learn Inventor after many years of using AutoCAD and I have run into a few different things that I've needed help with and this was one of them.
I think I have a good understanding of how constraints are being used in Inventor but when you wish to remove them from an item that still has me stumped.
But your solution here got me past my road block.
Radar
