Not only this. I still can't connect to the server. The problem may very well be in our network (firewall etc.) but the problem started when the change was made. The error reports as "Your 'autodesk.autocad.customer-files' folder was not polled for its unread count. Account: 'discussion.autodesk.com', server(...), Protocol: NNTP, Port: 118, Secure(SSL): No, Error Number: 0x800CCC0F". The port setting is not standard 119, but that has to do with our setup, and worked before the change.
Is it possible that any changes at Autodesk requires changes in my settings?
Per Engberg
