Inventor General Discussion
*Dotson, Sean
Message 21 of 25 (39 Views)
Re:
12-05-2002 01:28 AM in reply to: slightlyagitatedwookie
You could do it incontext.  Just select one of
the steel template files as the template when creating an incontext
part.
Sean Dotson, PE
href="http://www.sdotson.com">http://www.sdotson.com
Check the Inventor
FAQ for most common questions
href="http://www.sdotson.com/faq.html">http://www.sdotson.com/faq.html
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
I
am curious boilerchip as to exactly how you are using your "templates". I am
assuming that you never make your parts in assembly mode, but rather make your
parts in part mode and then bring them into your assembly. Or is there a way
you can build your parts in assembly mode using the save as
theory?
Distinguished Contributor
shastu
Message 22 of 25 (39 Views)
Re:
12-05-2002 01:32 AM in reply to: slightlyagitatedwookie
So what about part numbers, descriptions, and length with these templates. How does that all work when trying to create the Parts List in the .idw?
*Dotson, Sean
Message 23 of 25 (39 Views)
Re:
12-05-2002 01:49 AM in reply to: slightlyagitatedwookie
Since each is saved as a separate file you'd need
to manually enter the info into each part.  (some info which is common to
all steel shapes could be pre-entered into the template) but unique info would
need to be changed.
Sean Dotson, PE
Check the Inventor
So
.idw?
shastu
Message 24 of 25 (39 Views)
Re:
12-05-2002 02:02 AM in reply to: slightlyagitatedwookie
When you say "info which is common to all steel shapes" you mean info which is common to all sizes and shapes, don't you? If that is the case, I don't think anything is common as far as part numbers, descriptions, and lengths go.
*Dotson, Sean
Message 25 of 25 (39 Views)
Re:
12-05-2002 02:16 AM in reply to: slightlyagitatedwookie
I was just thinking out loud.  Maybe something
like: vendor or cost center etc...but I agree not a lot would be
common...
Sean Dotson, PE
Check the Inventor
When
go.
