Inventor Forum
New to Inventor and need help with Flat patterns
4 REPLIES 4
388 Views, 4 Replies
I am having difficulties creating a creating a sheet metal part in Autodesk Inventor to be able to create a flat pattern. I attached a PDF of the part I'm trying to create. The first page is the item I am trying to create. The next page are the 2 pieces I've been able to construct in Inventor but I can't seem to figure out a way to make it together. I also attached the Inventor model I was able to create.
How do I create this?
I am using Inventer 2013
4 REPLIES 4
IgorMir
Hi Allix,
Try this one. Please see the attached.
Best Regards,
Igor.
Web: www.meqc.com.au
in reply to: IgorMir
Thats pretty close to what I need. Is there a way to close the corners though?
IgorMir
Probably. Try to experiment with it. But I personally don't see a problem with it. It is not a big deal to weld them up.
Igor.
Ok. I will try. Thanks!
