Inventor General Discussion
*Mears, Brian
Message 1 of 3 (149 Views)
New Sheets & Sketched Symbols
149 Views, 2 Replies
11-07-2002 12:00 AM
My .idw files will have multiple sheets.  As I
add sheets, I need the revision block to appear on the sheet as well.  As
far as I can tell, there's no way for sketched symbols to automatically appear
on a sheet... for each sheet I add, I would have to add the revision block
manually, and populate the fields each time.
Am I right?  Is there a way to do this I'm not
aware of?
Thanks...
Brian
*Mears, Brian
Message 2 of 3 (149 Views)
Re: New Sheets & Sketched Symbols
11-07-2002 04:27 AM in reply to: *Mears, Brian
problem semi-solved.  I made the revision
block (header and initial revision) part of the border.  It should
work.
I add sheets, I need the revision block to appear on the sheet as well.
As far as I can tell, there's no way for sketched symbols to automatically
appear on a sheet... for each sheet I add, I would have to add the revision
block manually, and populate the fields each time.
not aware of?
Thanks...
Brian
*Dotson, Sean
Message 3 of 3 (149 Views)
11-07-2002 05:02 AM in reply to: *Mears, Brian
That's correct.  By adding them to the
titleblock or border (as you did) you can have them appear in each
sheet.
Sean Dotson, PE
href="http://www.sdotson.com">http://www.sdotson.com
...sleep is for the
weak..
not aware of?
Thanks...
Brian
Announcements
Need installation help?
