Inventor General Discussion
Distinguished Contributor
Raider_007
Message 1 of 15 (418 Views)
New marking menu disappearing off my screan at the bottom
418 Views, 14 Replies
06-10-2011 04:01 AM
Has anyone found a solution for the Marking menu that cuts off the bottom of the screen yet? This is very anoying that on some PC's if clicking somewhere closer to the bottom of the screen a portion of your context meny cuts off. If you click even lower then it jumps to the top but there is an area where it does not work.
Pieter
Product Support
jon.dean
Message 2 of 15 (412 Views)
Re: New marking menu disappearing off my screan at the bottom
06-10-2011 05:24 AM in reply to: Raider_007
I have tested on my two machines in sketch, part and assembly mode and I don't see the problem.
Maybe you should check your Graphic Card settings, you may have turned on Nview (NVidia) or ATI Control Center.
I would disable these utilities and do further testing.
Jon.
Jon Dean
Valued Contributor
stevenguy
Message 3 of 15 (347 Views)
12-07-2011 05:12 AM in reply to: Raider_007
I just install 2012 2 weeks and I have the same problem right click with new marking menu pull down missing feature pull down.
I like the marking menu but this right click missing thing really bother me a lot.
If the object you seleted in the middle of the scren then the click pull ussually missing last 2 feature.
See the 2 picture attached.
I hope there is fix for this.
I try many thing about the video setting and diffrent driver.
F.Y.I
We have 36 Inventors work station and they all have the same issue missing menu.
Steve Nguyen
CAD Admin/ Eng
Inventor Pro, Inventor Publisher & Vault 2012
Intel(R) Xeon(R) CPU X5690 @3.47GHz (2 processors)
Mem 48.0 GB
OS Win 7 64-bit
Graphic Card: Quadro FX 4800
*Expert Elite*
mcgyvr
Message 4 of 15 (339 Views)
12-07-2011 05:57 AM in reply to: stevenguy
Mine does the same thing.. Pretty annoying.
2015 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
Valued Contributor
stevenguy
Message 5 of 15 (323 Views)
12-07-2011 07:05 AM in reply to: mcgyvr
Where are you Autodesk?
What have we done wrong here? Tell us how to fix this unless this is the software bug.
We have 36 PC using Inventor Pro Win 7 SP1 64 bit.
We have 3 different card.
FX4800
FX4000
FX2000
All the driver version from Autodesk site.
Steve Nguyen
CAD Admin/ Eng
Mem 48.0 GB
OS Win 7 64-bit
*Expert Elite*
Curtis_Waguespack
Message 6 of 15 (322 Views)
12-07-2011 07:11 AM in reply to: stevenguy
Hi stevenguy,
The behavior you're seeing is just the way it is, unfortunately. I would expect that Autodesk will address this in a future release, or maybe even a fix for the current one, but I'm not aware of one at this point.
Another option is to change your right-click menu back to the classic menu if that helps:
http://inventortrenches.blogspot.com/2011/04/bring-back-classic-right-click-menu-in.html
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
*Expert Elite*
mcgyvr
Message 7 of 15 (318 Views)
12-07-2011 07:16 AM in reply to: Curtis_Waguespack
Curtis_Waguespack wrote:
Hi stevenguy,
Tell that to Autodesk.. They don't belive its happening.. (according to Jonny Dean up there)
Windows 7 64 bit
Valued Contributor
stevenguy
Message 8 of 15 (312 Views)
12-07-2011 07:19 AM in reply to: Curtis_Waguespack
Thanks Curtis
Autodesk,
I & my company like the new technology and new feature that help the designer move faster and all the control at the mouse point.
This is why we have subscription pay to support your engineer and we have to wait another year to get this bug fixed then we may have another one to lived with agian.
The marking menu right click is great and this little bug in the software and I have to give the marking menu is not acceptalbe.
I am sure there is a way to fix this.
Steve Nguyen
CAD Admin/ Eng
Mem 48.0 GB
OS Win 7 64-bit
Product Support
jon.dean
Message 9 of 15 (297 Views)
12-07-2011 07:44 AM in reply to: Raider_007
I have checked with development and we have had a few customers reporting this. Development are working to resolve this issue.
Jon Dean
Valued Contributor
stevenguy
Message 10 of 15 (238 Views)
02-08-2012 11:02 AM in reply to: jon.dean
Autodesk,
Any luck to fix this pull down disappearing off the screen yet?
Steve Nguyen
CAD Admin/ Eng
Mem 48.0 GB
OS Win 7 64-bit
Announcements
Need installation help?
