Has anyone found a solution for the Marking menu that cuts off the bottom of the screen yet? This is very anoying that on some PC's if clicking somewhere closer to the bottom of the screen a portion of your context meny cuts off. If you click even lower then it jumps to the top but there is an area where it does not work.
Pieter
I have tested on my two machines in sketch, part and assembly mode and I don't see the problem.
Maybe you should check your Graphic Card settings, you may have turned on Nview (NVidia) or ATI Control Center.
I would disable these utilities and do further testing.
Jon.
I just install 2012 2 weeks and I have the same problem right click with new marking menu pull down missing feature pull down.
I like the marking menu but this right click missing thing really bother me a lot.
If the object you seleted in the middle of the scren then the click pull ussually missing last 2 feature.
See the 2 picture attached.
I hope there is fix for this.
I try many thing about the video setting and diffrent driver.
F.Y.I
We have 36 Inventors work station and they all have the same issue missing menu.
Mine does the same thing.. Pretty annoying.
Where are you Autodesk?
What have we done wrong here? Tell us how to fix this unless this is the software bug.
We have 36 PC using Inventor Pro Win 7 SP1 64 bit.
We have 3 different card.
FX4800
FX4000
FX2000
All the driver version from Autodesk site.
Hi stevenguy,
The behavior you're seeing is just the way it is, unfortunately. I would expect that Autodesk will address this in a future release, or maybe even a fix for the current one, but I'm not aware of one at this point.
Another option is to change your right-click menu back to the classic menu if that helps:
http://inventortrenches.blogspot.com/2011/04/bring-back-classic-right-click-menu-in.html
I hope this helps.
Curtis
@Curtis_Waguespack wrote:Hi stevenguy,
Tell that to Autodesk.. They don't belive its happening.. (according to Jonny Dean up there)
Thanks Curtis
Autodesk,
I & my company like the new technology and new feature that help the designer move faster and all the control at the mouse point.
This is why we have subscription pay to support your engineer and we have to wait another year to get this bug fixed then we may have another one to lived with agian.
The marking menu right click is great and this little bug in the software and I have to give the marking menu is not acceptalbe.
I am sure there is a way to fix this.
I have checked with development and we have had a few customers reporting this. Development are working to resolve this issue.
Autodesk,
Any luck to fix this pull down disappearing off the screen yet?
I am also waiting for this answer too.
I think Autodesk want use to upgrade to 2013.
LOL
@stevenguy wrote:I am also waiting for this answer too.
LOL
Our company just upgraded from 2010 to 2012 last week. I don't think another upgrade for us is coming anytime in the near future...
@benemt wrote:Our company just upgraded from 2010 to 2012 last week. I don't think another upgrade for us is coming anytime in the near future...
Why 2012?? 2013's been out for a little while now.. Oh well.
There are many people having the same problem but I don't any solution for this matter from Autodesk.
I have this problem 1st day upgrade from 2011 to 2012. I thought it is resolution but I don't have this problem in INV 2011.
My company has 36 seats and they all acting the same.
We using all high end video card.
I contact my resaler and they have no idea how to fix the problem. I give up.
My compnay has subscription with Autodesk since 2008 thru 2012 and we just stop the subscription this year.
Disable the marking menu will stop this problem but I like the marking menu.
