Inventor Forum
New in inventor sheet metal and try to create flate pattern of a pipe
6 REPLIES 6
mgnshah
306 Views, 6 Replies
Hi to alll,
I am very new to inventor sheet metal.....i try to create a flate pattern of a attached file (pipe with contour arrangement).
Please help me with step by step procedure.
My purpose is to create a template for different sizes of pipe contour.
For attached file i try to create 2" pipe contor going through 6 in pipe. i am attaching standart part file for your reference.
I am using inventor 2013. I gone through some ideas from the Discussion Groups, but i am not able to do it.
ANKIT
6 REPLIES 6
JDMather
in reply to: mgnshah
One technique attached.
mgnshah
in reply to: JDMather
Thank you very much.....
Mark.Downes
Hi ANKIT,
Heres another method of achiving what you asked.
I changed the extrude to a Contour Flange and set Sheet Metal Defaults to your thickness.
cheers
Mark
Cheers
Mark
Inventor 2018, 3DS Max 2018, Vault 2018
JDMather
in reply to: Mark.Downes
If you set the flat pattern to wireframe view in your solution you will see that the edge of the cut is not perpendicular to the flat.
If the cut is made after folding the part this will be correct.
mgnshah
Thanks Mark....
mgnshah
Ya you are correct Mather,
It seems to be two edges at high valleys....but i tried to make a cut after folding but is not working. May be i am not able to get you.
Anyways, my worker cut the dotted edge (means took maximum distance between highest and lowest valley) and it came out very good.
One more thing is i set the compression factor as 1.
Thanks for interest,
ANKIT
