Inventor General Discussion
Distinguished Contributor
kstate92
Message 11 of 22 (690 Views)
Re: new free tech preview on Autodesk Labs: Project Simulus mechanical simulatio
04-24-2012 06:19 AM in reply to: mcmillr
Mainly, I wanted to make sure it wasn't just me.  Thanks for the info.  I have run a couple of static stress analyses and it has been nice to have.
KState92
Inventor Professional 2014 64 SP2
Windows 7 Pro 64 bit - SP1
Xeon E5-1620
16 GB Ram
Quadro 4000
Board Manager
scott.sheppard
Message 12 of 22 (624 Views)
05-15-2012 10:59 AM in reply to: kstate92
I just posted a new build for download.
http://labs.autodesk.com/utilities/kraken/
Scott Sheppard
Program Manager
Autodesk Labs
New Member
StagerB
Message 13 of 22 (588 Views)
05-24-2012 07:35 AM in reply to: scott.sheppard
Question: In the Thermal Steady State analysis is there a way to see deformation scale by applying various temperatures? Or is this still in development?
Employee
henderh
Message 14 of 22 (576 Views)
05-24-2012 08:41 AM in reply to: StagerB
Hi StagerB,
  Yes, it does.  Attached is a deformation image of a coupled thermal stress simulation, where two strips of dissimlar metals are bonded and then raised 20 degrees C from the intial temperature.
  Please let us know if you have additional questions, comments or suggestions.
Thanks! -Hugh
Hugh Henderson
Simulation QA Engineer
DLS
Dan.M
Message 15 of 22 (544 Views)
05-26-2012 08:49 AM in reply to: henderh
Can we have a tutorial in which the thermal boundaried are explained?
For example lets take a steel pipe in wich the inside surface is heated to 80 C
and we can see whats the temp on the outside surface.
Dan
Dan.M
Message 16 of 22 (543 Views)
05-26-2012 09:00 AM in reply to: henderh
For example in the picture, i would expect to see the
heat expand trough the part and get cooler temp on the outside.
Maybe mysetup is wrong, I dont know
Dan
New Member
Vitellik
Message 17 of 22 (494 Views)
06-09-2012 02:00 AM in reply to: scott.sheppard
I am trying to use it for thermal steady evaluation of thin layers (steel plates) insulated.
I have to apply convection inside and outside.
Two issues:
1. I get an error about my thin object:
                 230264.sim: Study 1 - Thermal: Error: Body 'Simulation Model:1/230264.iam:1/230264_SFT:1' is thin.
                 230264.sim: Study 1 - Thermal: Asynchronous cloud solve failed.
2. may I change properties to customized materials?
Apart from this, looks to be a very easy to use interface.
Mario
Employee
henderh
Message 18 of 22 (474 Views)
06-11-2012 09:28 AM in reply to: Dan.M
Hi Dan,
  The initial temperature is 20 deg C, or 68 deg F (room temperature) unless an applied temperature exists.
  For your pipe or wheel rim example, you would need to apply different temperatures to different faces for steady-state heat transfer to occur.  Either that or apply heat flux or convection to the other face(s) that do not have the applied temperature.
 By applying a single temperature to one face or a set of faces, in steady-state, the entire part will eventually become that specified temperature.  This is because there is no heat leaving the body, as faces without any applied 'boundary condition' is treated as adiabatic (no heat transfer).
  One thing to keep in mind is that you cannot apply an applied temperature + heat flux (or convection, etc) to the same face.  It is somwhat similiar to applying a force and fixed constraint to the same face in LSS.
  Hope this helps!  Please let us know if you have any additional questions, comments or suggestions.
Best regards, -Hugh
Hugh Henderson
DLS
Employee
mcmillr
Message 19 of 22 (451 Views)
06-12-2012 05:53 AM in reply to: Vitellik
Mario, unfortunately there is a limitation in the Simulus tech preview which is preventing it from processing parts that are very thin. We should be able to handle these sorts of models in a future update.
Sorry for the inconvenience.
Robert McMillan
Project Simulus Team
Dan.M
Message 20 of 22 (425 Views)
06-12-2012 01:07 PM in reply to: henderh
I love Simulus. It is awsome. When can we have this as part from Inventor. Next week maybe ? :smileyhappy:
Also we would like to have a launcher from Inventor to Simulus.
Dan
