I just start to use IV6. I am wondering for so called improved Holechart and
revision feature in idw, after adding new field as additional column, how to
input value? I guess this shall be similar to what it is in partlist --
create a custom property with the same name as new field. I've tried with no
avail. I am sure I missed something, but what? Should autodesk have done
this the same as partlist?
In addition, how to input value for "Description" column which comes as
default --" value" for revision box? I've tried "Description" from both ipt
and idw property.
In the first place, it was claimed by autodesk that holechart has much
improved. I presume this is going to be the same as in AutoCAD Mechanical.
In fact, it's not. Even worse, it still inherit nasty stuff from 5.3, like
the line spacing is too wide for couterbore hole note. Any way to adjust it.
Anyone sheds some light on me?
