Inventor Forum
New error message
4 REPLIES 4
waynefisher
203 Views, 4 Replies
New error message
So here is an error message I have been seeing lately. It is leaving my model crippled. It can't be good when you see Asian and English mixed together.. Attached is a zipped file containing the two *ipt files for analysis. One is a layout as noted.
4 REPLIES 4
Paul-Mason
in reply to: waynefisher
I've had something similar in the past a system reboot fixed it.
Inventor 2023 Pro
HP Z420 workstation
Xeon 3.7Ghz CPU 8 Cores, 64 GB Ram
64bit (The Garbage known as) Windows 10 Pro
AMD FirePro V3900 (ATI FireGL) (1GB RAM)
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
Hi waynefisher,
I don't have any ideas, but here is a related thread:
http://forums.autodesk.com/t5/inventor-general-discussion/invalid-reference-to-segment-object-used/m...
I hope this helps.
Curtis
johnsonshiue
Hi! It seems that the segment handling materials in the part file is corrupted. Do you have other parts exhibiting similar behaviors? Are you using custom material library?
Thanks!
Software Test Engineer
waynefisher
in reply to: johnsonshiue
I dbl click the material in the Inventor Material Library, then adjust them above, (turn off tint, rotate grain, ect). I have attached a part as a sample, this one does not crash Inventor.
