So here is an error message I have been seeing lately. It is leaving my model crippled. It can't be good when you see Asian and English mixed together.. Attached is a zipped file containing the two *ipt files for analysis. One is a layout as noted.
Hi waynefisher,
I don't have any ideas, but here is a related thread:
I hope this helps.
Curtis
Hi! It seems that the segment handling materials in the part file is corrupted. Do you have other parts exhibiting similar behaviors? Are you using custom material library?
Thanks!
I dbl click the material in the Inventor Material Library, then adjust them above, (turn off tint, rotate grain, ect). I have attached a part as a sample, this one does not crash Inventor.
