I must be missing the trick, but when the lower case i in the white circle appears in your browser tree:
I don't understand why won't any help or, you know, INFO appear when you hover the cursor over this icon?
Read the step file translation report: no errors. Save, close, reopen the file: still an 'i', but nothing else that I can sense.
What's the point if it won't tell me anything? What am I missing here?
Solved by JDMather. Go to Solution.
If you send to the construction environment and do a quality analysis it will show you (right click-find in window) what is wrong.
That was it: Construction > Repair > Copy, Delete Original
But a little more visual feedback of the initial error would be nice.
