Add the manifold to an assembly, add another part (heretofore named
Toolbody) larger than this manifold, derive into a new part subtracting the
manifold from the toolbody. Delete the exterior faces (do not heal) of the
Toolbody and this should only show the remaining holes as solid material.
Use this throughtout the final development as it will update as required.
"Jay Muchemore" wrote in message
news:4242f430$3_2@newsprd01...
> The file is a part and part files don't have that capability...at least
not
> in IV 7. Even if it were in an assembly, I couldn't get what I want.
> Basically, I have a rectangular block with lots of holes. I need to make
> sure the holes don't cross where they're not supposed to and do cross
where
> the need to. I need a solid of the feature and creating an ifeature of
them
> doesn't work.
> "Troy Grose" wrote in message
> news:1516787.1111680909394.JavaMail.jive@jiveforum1.autodesk.com...
> > If I understand your question correctly
> > Can you not do a half section view??
