>Can the problem be because I was trying to mate edges and not surfaces?
I can mate edges with negative or positive but get same results as negative to edges is not entirely defined.
I'm not sure exactly what your picture was supposed to show, but I am interested in your use of Move Face as I have not found many uses for that command.
Just went back and saw the text in your picture about +/- giving same results. When you pick a face that defines the normal direction for the offset. (Face has a front side and a back side.) An edge is partially ambiguous as normal direction is not defined.
Edited by: JDMather on Aug 12, 2009 9:41 AM
