I need to kown the digit displayed at right hand side bottom corner, i guess its a number of parts imported in inventor assembly, but it's not matching as per parts.
Solved by CCarreiras. Go to Solution.
Hi!
First number is the total number of elements in Assembly.
The second number is open documents in memory.
http://help.autodesk.com/view/INVNTOR/2015/ENU/?guid=GUID-8DEEA4F5-00FC-4BF4-AF1B-C00A0224F838
Did you find this reply helpful ? If so, use the Accept as Solution or Kudos - Thank you!
