Inventor Forum
Need to import surfaces from old MDT file.
6 REPLIES 6
jpblower
297 Views, 6 Replies
All I can get is 3d lines or ACAD_PROXY_ENTITY.  Since the newer versions of IV did away w/ MDT I don't have any way of converting them.  Does anyone know what I can do.?
6 REPLIES 6
mcgyvr
in reply to: jpblower
IDK.. you might be screwed
http://www.augi.com/library/creative-inventor-mdt-translations-revisited/
jpblower
in reply to: mcgyvr
But I don't want to be attached to another on an inclined plane wrapped around a helical axis.
RogerMollon
Have you tried exporting the MDT model to a STEP file and then importing the STEP file into Inventor?  Since you appear to only be concerned about geometry this should work.
I hope this helps.
Roger Mollon
Forge - Strategic Tech Consultant - Novi
Autodesk, Inc. - Retired
Hi jpblower,
I couldn't determine if you had access to MDT currently and couldn't get the results you wanted, or if you currently don't have MDT but wish you did so that you could try to use it to output your data. If the latter is the case, this link might be of interest:
http://inventortrenches.blogspot.com/2011/05/where-to-download-mechanical-desktop.html
Your ability to obtain and install MDT from the link might depend on the version of Inventor you have.
 I hope this helps.
Curtis
jpblower
in reply to: RogerMollon
If I can get a step (iges, sat, dxf, 3ds, et al)  file to work it comes in as 3d lines.  The issue now becomes getting IT to retrieve an old copy of MDT.
Thanks.
Thanks, I sent the link to our install guru.
