Hello everyone!
I need to build a dynamic simulation for a (very) simple assembly, but I can't find the apropriate JOINT type to use.
I would need something like a "point-to-path" joint (similar with point-to-line).. but, of course there is nothing like this ..:)
The simulation involve a trolley which must follow a rail path. (Please see ATTACHED zip)
This rail is similar with a roller coaster shape (3d sketch .. etc...model done!)
I've easily built the components, but I can't figure out how can I constrain/joint the trolley to the rail.
Of course, I have to get a final AVI with this, eventually, but this is the easy part ..
I have to admit that I'm a beginner in dynamic simulation and (the most important!) I must finish this until Tuesday, Aug 13th..:(( So, there is not much time to buy books or deep studying.
I've already started reading the Autodesk help & tutorials... but I'm pretty sure I can't learn it in two days.
Thank you.
Adrian
adistratulat@yahoo.com
Thanks, but as I said, I need to do it with Dynamic Simulation module...
The problem is that I need a 3D path to move the ball (trolley) and will be also a force applied there, etc.
And, actually the method you described is called "driving constraint" as I know (not animate constraint ...)
Please, other ideas..??
Animate Constraint is done in Inventor Studio, not Drive Constraint.
It will take you several months to learn Dynamic Simulation.
Search Amazon for the Wasim Younis book to get started.
Thanks JD
I know that will take long time to learn Dyn.Sim.
I know about Wasim Younis books.
But, as I said in my initial message, there is no time for deep study at this moment.
That's why I yelled for help here... I need just "the tip" to use in that scenario, then I will dig deeper.
Please don't mind, but your advice like "you have to learn" ... is not a point/tip.
Thanks anyway.
Just press the "EASY" button..
http://www.youtube.com/watch?v=cjkgEqTpeSk
