Inventor Forum
Need ilogic to automatically select 'Master' LeveofDetail
2 REPLIES 2
247 Views, 2 Replies
Hi all,
I have a master assembly, using 'SavecopyAs' command I am creating copy of this assembly  with few parts suppressed (LevelofDetail1).
In the newly created assembly I need to export BOM automatically using below command. But it is possible only when levelofDetail is in 'Master' not in 'LevelofDetail1'. I am looking for a code that automatically activate 'Master' and execute the Export.BOM command.
ThisBOM.Export("Parts Only", "RoofpanelBOM.xls", kMicrosoftExcelFormat)
Looking for help
Rudresh
2 REPLIES 2
CCarreiras
Hi!!!
Yes, i already seen a code for that... but i can't remember how it is...
Place your question in the forum: "Inventor Customization", it´s the proper forum for iLogic questions.
There, you will find the answer quickly.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
Curtis_Waguespack
Hi rudresh_middleby,
I replied to your other thread on the Customization forum. I'm just linking this thread to that one in case someone finds this thread in a future search:
http://forums.autodesk.com/t5/Inventor-Customization/Ilogic-to-automatically-set-LevelofDetail-to-Ma...
I hope this helps.
Curtis
