Inventor Forum
need help with this shape
5 REPLIES 5
403 Views, 5 Replies
how would one model up this part shape?the part of the model i need some guidance with is where the black lines are situated...using 2013
how would you make this shape?
Simon
5 REPLIES 5
cwhetten
How accurate of a shape do you need?  Are you actually manufacturing that pump body, or is it just a representation for use as a purchased component?
If it's the latter, then you could create a coil feature (spiral, not helix).  Then sweep the last segment for the vertical discharge.
Search the forum for "volute" and you may find some good results.  I think this question comes up frequently.
Attach what you have so far and someone may be able to help you further (I am on 2012).
in reply to: cwhetten
Hi cwhetten
I never even thought of the coil feature .. will try that method..
It is for representation.
I have attached a example but i would like to get the shape a liitle more accurate...i took a picture of my attempt
If you do have some time could you give me a example using the coil feature please for the picture i attached previously
thanks for the tip
Simon
cwhetten
Attached is an example of using the coil feature and a sweep.  I actually had to use two coil features because Inventor will not allow a coil feature to intersect itself.
You can tweak the two user parameters to change the sizes.
If its only for representation, then I probably woudnlt use the coil feature as its pretty memory intensive and will bloat your file size unnecesarily, put a few of these pumps in a mechanical ga and see how your performance drops off
I would just approximate the shape with a couple of arcs, extrude and fillet the edge
ps...warman provide 3d blocks of most of there pumps if you contact them
cheers for the example and suggestions.Gives me some things to work with
Simon
