Inventor Forum
need help with this shape
5 REPLIES 5
simon_toaldo
400 Views, 5 Replies
how would one model up this part shape?the part of the model i need some guidance with is where the black lines are situated...using 2013
how would you make this shape?
Simon
5 REPLIES 5
cwhetten
in reply to: simon_toaldo
How accurate of a shape do you need?  Are you actually manufacturing that pump body, or is it just a representation for use as a purchased component?
If it's the latter, then you could create a coil feature (spiral, not helix).  Then sweep the last segment for the vertical discharge.
Search the forum for "volute" and you may find some good results.  I think this question comes up frequently.
Attach what you have so far and someone may be able to help you further (I am on 2012).
simon_toaldo
in reply to: cwhetten
Hi cwhetten
I never even thought of the coil feature .. will try that method..
It is for representation.
I have attached a example but i would like to get the shape a liitle more accurate...i took a picture of my attempt
If you do have some time could you give me a example using the coil feature please for the picture i attached previously
thanks for the tip
Simon
cwhetten
Attached is an example of using the coil feature and a sweep.  I actually had to use two coil features because Inventor will not allow a coil feature to intersect itself.
You can tweak the two user parameters to change the sizes.
If its only for representation, then I probably woudnlt use the coil feature as its pretty memory intensive and will bloat your file size unnecesarily, put a few of these pumps in a mechanical ga and see how your performance drops off
I would just approximate the shape with a couple of arcs, extrude and fillet the edge
ps...warman provide 3d blocks of most of there pumps if you contact them
simon_toaldo
cheers for the example and suggestions.Gives me some things to work with
Simon
