Inventor Forum
Need help with shell option. Deathstroke Mask
12 REPLIES 12
Message 1 of 13
877 Views, 12 Replies
Hi guys!
I am creating a new model (a mask) that i need to add a shell to so i can print it. I am new to this and i need help. When i try to use the shell function it responds with an error message (Could not shell. The selected component has no volume.). I was also hoping to smooth out the model.
The mask is one of Arkham Deathstroke for those interested. Nerd lol
Any help given would be great and i would be very thankful.
12 REPLIES 12
Message 2 of 13
PaulMunford
It sounds like you're model is a surface. Try using the thicken command instead.
Autodesk Industry Marketing Manager UK D&M
Opinions are my own and may not reflect those of my company.
Linkedin Twitter Instagram Facebook Pinterest
Message 3 of 13
JDMather
The image you posted is not of an Inventor file.
Can you attach the Inventor *.ipt file here?
Did you import this from an stl file?
More information is needed.
Message 4 of 13
in reply to: PaulMunford
I get the same error message when i try the thicken command
Message 5 of 13
mcgyvr
ummm... Are you creating this in the drawing environment.
You should be creating (and posting here) a part file (ipt extension).
A drawing file (idw or dwg) is how you create a 2d drawing of a 3d part. You don't create your 3d part in a drawing file.
Message 6 of 13
in reply to: mcgyvr
i have no idea what i am doing here
Message 7 of 13
JDMather
You didn't answer my previous question.
Did you create that geometry?
That is an imported stl file - generally of little use other than for reference in an engineering software like Inventor.
You might have more luck with that in Fusion 360 or....
www.meshmixer.com
Have you installed Service Pack 2 for Inventor 2014?
Message 8 of 13
in reply to: JDMather
it was orginally a pdo file exported as an stl
Message 9 of 13
JDMather
Did you observe that it is coarsely faceted planar triangles rather than smooth surface?
Message 10 of 13
mcgyvr
Thats a "mesh".. Its not a 3d part as it has no thickness/volume.
You need the mesh enabler add-in which allows output from various "graphics" programs to become solid models.
Assuming you are a student you will need to email Scott Shepard from Autodesk and ask him how to get it.
If you are a professional just log into the autodesk app store and download it.
Message 11 of 13
in reply to: mcgyvr
Thanks for the help. I am checking out the Mesh Enabler to see if that works
Message 12 of 13
in reply to: mcgyvr
dude thanks. that worked out great!!
Message 13 of 13
JavaLodge
When you're done, be sure and post a picture in the next Friday Pictures so we can see the result. 😄
____________________________________________________________
Slow is good and good is fast.
