So I created a 2-d sketch and made it 3-d using sweep. I'm trying to use the rectangular pattern tool to copy the object 9 times in a certain direction. I created a line that points in the direction I want, but when I try to click on it, the rectangular pattern tool will not allow me. Are there any suggestions as to how I can do this? Thnk you!
Sincerely,
Melissa
Solved by JDMather. Go to Solution.
Try selecting Axis rather than sketch line.
Attach your file here if you can't figure it out.
The CADWhisperer YouTube Channel
Is there a way to draw an axis tangential to a circle? Whenever I click axis, it puts the axis right through the middle of the circle. Thanks!
My guess is that you already have an axis - the X, Y or Z axis.
If those are not appropriate then you can use a sketch line to define a new axis.
Attach your ipt file here and end all doubt within minutes (or seconds).
@mns3fa wrote:
... I created a line that points in the direction I want,...
Sincerely,
Melissa
Did you try clicking on this line to create your axis?
Looking at your file - my guess is the existing X-Axis is what you needed to select.
Got it. And is there a way to move a rectangular pattern in a specified direction? I can't seem to find a way. If not, how do you create a 2-D sketch that lies at a certain depth in the 3rd dimension?
