Inventor Forum
Need Help with Rectangular Pattern
9 REPLIES 9
Message 1 of 10
mns3fa
758 Views, 9 Replies
  So I created a 2-d sketch and made it 3-d using sweep.  I'm trying to use the rectangular pattern tool to copy the object 9 times in a certain direction.  I created a line that points in the direction I want, but when I try to click on it, the rectangular pattern tool will not allow me.  Are there any suggestions as to how I can do this?  Thnk you!
Sincerely,
Melissa
9 REPLIES 9
Message 2 of 10
JDMather
in reply to: mns3fa
Try selecting Axis rather than sketch line.
Attach your file here if you can't figure it out.
Message 3 of 10
mns3fa
in reply to: mns3fa
Is there a way to draw an axis tangential to a circle?  Whenever I click axis, it puts the axis right through the middle of the circle.  Thanks!
Message 4 of 10
JDMather
in reply to: mns3fa
My guess is that you already have an axis - the X, Y or Z axis.
If those are not appropriate then you can use a sketch line to define a new axis.
Attach your ipt file here and end all doubt within minutes (or seconds).
Message 5 of 10
JDMather
in reply to: mns3fa
@mns3fa wrote:
...  I created a line that points in the direction I want,...
Sincerely,
Melissa
Did you try clicking on this line to create your axis?
Message 6 of 10
mns3fa
in reply to: mns3fa
Here's my file.. I'll try what you suggested while you take a look
Message 7 of 10
mns3fa
in reply to: mns3fa
I got it! Thanks for your help!
Message 8 of 10
JDMather
in reply to: mns3fa
Looking at your file - my guess is the existing X-Axis is what you needed to select.
Message 9 of 10
mns3fa
in reply to: mns3fa
Got it.  And is there a way to move a rectangular pattern in a specified direction?  I can't seem to find a way.  If not, how do you create a 2-D sketch that lies at a certain depth in the 3rd dimension?
Message 10 of 10
mns3fa
in reply to: mns3fa
I just want to move the 2nd rectangular pattern in the y-direction
