So I have created a custom template for W-Beam creation and I've been able to get iLogic to generate the description for me, "almost", in the format I need, but the LENGTH is just showing up as a number, when it needs to be to (2) decimal places and show trailing zeros.
example: BEAM, W6X9, (34.00" LONG)
what iLogic is giving me: BEAM, W6X9, (34 LONG)
below is some info to help me figure out what I need to do. I've tryed rounding, but either I'm doing it wrong or it's not working for this example.
Any help would be great as I can't rool out this template until the description is fixed.
Chris
Hi!
It's easier to find solution and help for these kind of questions here:
http://forums.autodesk.com/t5/inventor-customization/bd-p/120
Did you find this reply helpful ? If so, use the Accept as Solution or Kudos - Thank you!
