Hello all,
This is my first time here posting in the forums so I'll jump right into it. I am doing a project in class in Inventor 2010. I have a track with and a car I am trying to tangentialy to mate to the track, then I would like to apply gravity to the car and have it run on its own.
First off I have an assembly of my car
It has two bearings on the bottom there, the rest it basically for show. I want to constrain those bearing to the track.
But i'm having trouble actually getting it to stay on the track. Any suggestions?
Also if any one has any insight once I figure out how to constrain the car to the track to go about applying gravity or running something similar to a motion study in solid works It would be greatly appreciated.
Solved by JDMather. Go to Solution.
I have gotten the car mated to the track now, I just needed to add one more constraint.
But still if any one has any information how to use gravity in the assemblies if you would be so kind to shed some light.
-Thanks
@rd_k2 wrote:how to use gravity in the assemblies if you would be so kind to shed some light.
-Thanks
Attach your assembly here (include iam and all ipt files) or search here http://www.amazon.com for book by Wasim Younis or check Help Tutorials for tutorials on Dynamic Simulation.
See similar animation here http://208.74.205.69/t5/Autodesk-Inventor/Marble-moving-along-an-helical-path/m-p/2868416
Thanks for the reply!
I have attached a zipped folder of the ipts and iams that I have for the project. I've messed around with the dynamic simulation for a little bit and was able to define gravity and put one rolling constraint on the bearing and track but It wont let me do the other. Hope you can help, thanks again!
Use Transitional constraints rather than Tangent constraints.
But that only gives kinematic motion in assembly (no gravity).
For Dynamic Simulation you need a Planar joint to side of slide and a 2D Contact joint.
You would need to create a couple of sketches for the 2D contact boundary loops.
I am using 2012 - so you wouldn't be able to open my solution.
I could post screen captures - but I am a bit busy right now.
You might need to remind me by bumping this thread a couple of times over the next week until I (or someone) responds.
Thanks for the help, I'll give it a go in the morning tomorrow. And I'll keep bumping the post for some screen shots. As mentioned before you were using Inventor 2012, would the process be very different from recreating it in 2010?
The process is no different.
You don't need any 2D sketches - this one is trivially easy and covered in the Tutorials and book I suggested.
Add a Mate-Flush constraint between the WorkPlane1 of the Track and the XY Plane of the Front Bearing.
Dynamic Simulation will convert this to a Planar Joint.
Go to Dynamic Simulation.
Make sure Convert Constraints is activated.
Right click on the apple to Define Gravity
Add 2D Contact by selecting the edge of the front bearing and the edge of the track.
Repeat creating another 2D Contact Joint selecting an edge of the rear bearing and the edge of the track.
Think of these edges as creating extruded surfaces midplane to infinity. These surfaces cannot penetrate each other.
Run the simulation. The first time it will be a little slow calculating but then Rewind and Play again.
Your browser should look like this.
Hey I rely appreciate your help, I got it all going now and working, I clicked accept as solution on the final post. Thanks again!
