Inventor General Discussion
Member
purushottam2
Message 1 of 6 (485 Views)
Need help to automate inventor
485 Views, 5 Replies
11-22-2012 09:53 PM
HI All,
I am new for the Autodesk, I have 5 year of experince in .net (C#) programming. I want to automate the autodesk inventor software. Basically my need is to automate design of Base Plate of a Pole.
My requirement is that, i will build an application that will read all the input from any .csv file and will call the inventor API and it will create the design and will save at hardrive.
First of all i want to know, Does Autodesk API provide such functionality to automate the whole process?
Thanks in Advance.
hi,
while in inventor Alt+F11
or
ribbon, manage tab, vba.
the application project will be visible in the API window. if you have a document open, the document project will also be visible in the API window.
the application project is targeted in inventor, tools, options, file tab, default vba project.
there is some helpful resources around. start in the inventor, customisation forums.
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/Check-out-the-self-paced-guide-My-First-Plug-in/td-p/3115642
ps- also a favorite and skilled person for anyone to search posts from is :
Brian Ekins, Autodesk Inventor API
PaulMunford
Message 2 of 6 (472 Views)
Re: Need help to automate inventor
11-23-2012 12:05 AM in reply to: purushottam2
You have lots of options here depending on what level of automation you require.
Inventor will read in fom an Excel spreadsheet nativly, so you can set this up maually and then use iLogic or VBA to save out the copies on the appropriate trigger.
iLogic itself has an API for accessing Excel spreadsheets, so you can automate the whole thing with iLogic if you need to.
http://inventortrenches.blogspot.co.uk/2011/04/using-excel-and-ilogic-to-retrieve-part.html
If you want to run this independatly of Inventor, you can use the API which accepts VBA, VB.net C and C#
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1079044
If you want to run this via a web client look at Inventor Intent:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=18361292
http://wikihelp.autodesk.com/Inventor_ETO/enu/2013/Help/0148-Inventor148/0351-Autodesk351
CSO
The CAD Setter Out Blog @CadSetterOut
Inventor Surfacing | AutoCAD | CAD Standards
Please use the Mark Solutions! Accept as Solution or Give Kudos! Kudos functions - Thank you!
Member
purushottam2
Message 3 of 6 (459 Views)
11-23-2012 02:38 AM in reply to: PaulMunford
Thanks for your promptness :smileyhappy: I will build my own user interface on the .net framework that will read all the input parameters that required to inventor API. Can you let me know from where i can get some information about all the API. I am confused how to start. I have seen a sample api code that hide the component, in the API learning section. My objective to automate the whole design process. For example i will save all the inputs parameter in the CSV file, and my .net application will read the input and call the Inventor api then it will save the design. User's do not need to open the inventor, each step should be done by .net application via calling API. Thanks for your support....!!!!!!!!!!
Mark_Wigan
Message 4 of 6 (456 Views)
11-23-2012 02:52 AM in reply to: purushottam2
You can access API supporting documentation from within inventors API window by firing the help on any function.
there is also a customisation forum under inventor discussions forums. There are lots of helpful people there as well.
best regards,
- Mark
(Kudo or Tag if Solved - it may help others)
PDSU 2015 Windows 8.1, 64bit.
Member
purushottam2
Message 5 of 6 (451 Views)
11-23-2012 03:00 AM in reply to: Mark_Wigan
Thanks for your reply..
Sorry i did not understand your line "You can access API supporting documentation from within inventors API window by firing the help on any function." Form where i can access Inventor API Window?
I am new to autodesk so may be i am annoying you...
Mark_Wigan
Message 6 of 6 (418 Views)
11-24-2012 06:42 AM in reply to: purushottam2
hi,
or
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/Check-out-the-self-paced-guide-My-Firs...
best regards,
- Mark
